Hi All,
I am using Honeybee to model the energy requirements of a residential building. I assigned loads and schedules to every zone. However, when I pass my HBZones to the RunEnergySimulation component, the zone programs, setpoints, and loads return to the default value (see attached image).
Does anybody know why this is happening, and how can I fix it?
Hi @LizRivera
If you go to with your mouse pointer to the import idf file it will give you the folowing message:
import an idf file to gh
This version only imports the geometries
Constructions, schedules and systems will be neglected
If you open the openstudio file, you will see the zoneprograms are assigned in the right way.
Oh, I see. Thank you so much @Erikbeeren !!!
