With these plugins, the block can work, or it works only in a single unit.
And that manual measurements can enter this plugin or only accept epw.
And how do I fix the error.
You are using a very old version of Grasshopper and Rhino. Update Rhino and Grasshopper and this issue will be resolved.
OK, Thanks.
You can model a number of buildings as well as a single building.
You can modify an epw file and replace the data with your measurement. You can’t import the measured data directly.
So, for the sub-climatic (local), the exact result is not
