Is there a way to save a grasshopper script so it remembers the last results next time I open Rhinoceros and the script? Currently I need to run the script every time I open Rhinoceros again to get back to my results, that is really time consuming.
you can connect the output from any component to the native grasshopper Data component. Then, right-click and internalise data. Now that result / geometry is saved inside the Data Component. It will be available for use the next time you open the file.
In addition to @devang’s suggestion, please check if the output results are stored in files (not all components have them). Then you can recall them from those files instead of simulation the whole thing.
