Hi everyone,
After using “Honeybee_SolveAdjc”, some walls can not be splited to the interior and exterior. The purple parts in the pic should be exterior. Can anyone give me some suggestion?
wuyi04162.gh (580.5 KB)
Hi everyone,
This should me manually split in rhino or Grasshopper please. As you gain more experience with zoning, you’ll start to plan for such surfaces in advance.
As I opened the file, SolveAdjacencies
component doesn’t intersect, You need to use the Honeybee_IntersectMasses
component before creating the zones. After checking that, follow @devang suggestions.
Hi devang, thank you for the reply. I’ll try to redo it.
Hi OmidmRashidi, thank you for the help. I forgot this component.
