How to control 3 chillder operation scheme for load ratio using ironbug?
This project has 3 same capacity chiller. The operation scheme is: 0-33% total load ,chiller 1 on. 33%-66% total load chiller 1 and 2 on. 66%-100% total load chiler 1\2\3 on. I tried to use IB_PlantEquipmentOperationCoolingLoad for this case, ironbug generated 3 chilled water loop.
Then run Energyplus , here is the error.
Program Version,EnergyPlus, Version 23.1.0-87ed9199d4, YMD=2024.03.09 12:41,
   ** Severe  ** <root>[PlantEquipmentOperation:CoolingLoad][Plant Equipment Operation Cooling Load 1] - Missing required property 'load_range_1_lower_limit'.
   ** Severe  ** <root>[PlantEquipmentOperation:CoolingLoad][Plant Equipment Operation Cooling Load 1] - Missing required property 'load_range_1_upper_limit'.
   **  Fatal  ** Errors occurred on processing input file. Preceding condition(s) cause termination.
   ...Summary of Errors that led to program termination:
   ..... Reference severe error count=2
   ..... Last severe error=<root>[PlantEquipmentOperation:CoolingLoad][Plant Equipment Operation Cooling Load 1] - Missing required property 'load_range_1_upper_limit'.
   ************* Warning:  Node connection errors not checked - most system input has not been read (see previous warning).
   ************* Fatal error -- final processing.  Program exited before simulations began.  See previous error messages.
   ************* EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
   ************* EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 2 Severe Errors; Elapsed Time=00hr 00min  0.35sec
I used Ladybug Tools 1.7.26 verison.Please help me for right setting for this case. And is there a way to use EMS program for this operation?
Hi @minggangyin
You can set this “LoadDistributionScheme” of your plantloop to “SequentialLoad” and hard-size all your chillers.
Plant load scheme.gh (52.9 KB)
This is what I get of each chiller’s electricity use rate to prove that three chillers are running sequentially.
Hi @MingboPeng
It is great. I will try this workflow today. Thanks for your reply
