Reloading results
Hello everyone
Is there a way to reload daylighting results (sda) from a previous hb+ run back into honeybee+.
thanks in advance
Hi @FabianPosadas,
Yes. Set reuse matrices to True in recipe and Honeybee[+] loads the results currently available instead of rerunning the simulation. The number of reuse matrix inputs is different for each component. For instance for daylight coefficient recipe it is only one.
Cache last results
