Hello!
How do I save my daylight simulation results (colored mesh/legend) as images on my harddrive?
Hello!
@Astaahl,
You can use Ladybug_Capture View component to capture from Rhino viewport.
see Hydra example.
Hi , either your use the rhino command print as jpg or you use the ladybug component mesh-to-hatch and use the rhino export command.
