Rhino 6 - SplitFloor2ThermalZones
@chris, could you check Honeybee_SplitFloor2ThermalZones component in RH 6 before your Rhino is valid?
SplitFloor2ThermalZones.gh (497.0 KB)
Rhino 6 and Honeybee Intersect masses issue
@hdimor.mr ,
I moved this question to its own topic as this is separate from the splitBuildingMass issue. @SaeranVasanthakumar is the author of the current SplitFloor2ThermalZones component and he may have a better idea of how to add Rhino 6 support than I do. Still, I’ll look into it and see if I can find the cause of the issue.
@chris, I can take a look at this problem. It might take a while because I haven’t downloaded Rhino 6 yet, and haven’t worked with any of its libraries… but I guess I can’t avoid the inevitable switch towards it anymore :slight_smile:
@hdimor.mr can you clarify what bug is occuring in the component?
Hi @SaeranVasanthakumar ,
Honeybee_SplitFloor2ThermalZones error report:
Runtime error (MissingMemberException): 'NoneType' object has no attribute 'ToBrep'
  line 2112, in straight_skeleton, "<string>"
  line 2172, in main, "<string>"
  line 2246, in script
Rhino 6:
Rhino 5:
I can confirm that the part of the code that’s failing is the extrusion of the curve, which seems particularly odd. If I get time to look deeper into it, I’ll report back here.
