Ladybug_ENVI-Met Release
I’m glad to share some useful tools with those people who use ENVI-Met v.4.0 for their researches. (a software that is very slow but accurate enough, XD).
I have written two LB components which let you visualize and manipulate data that come from ENVI-Met simulations. These component are based on a research with ENVI-Met v.3.0 and Ladybug that I did in 2015:…
It is possible to combine LB_ENVI-Met Grid with other LB component, such as: Ladybug_Mesh Threshold Selector, Ladybug_Countour Mesh, Ladybug_Recolor Mesh, Ladybug_Outdoor Comfort Calculator, Ladybug_Thermal Comfort Indices.
  • Antonello
Excellent Antonello!
Would try these as soon as possible. Thanks a lot.
Hi Antonello,
This is good news.
The Reader component is giving this error when you just insert it:
  1. Solution exception:‘unicodeescape’ codec can’t decode bytes in position 383: malformed \N character escape
Good job … :slight_smile:
Hi Abraham,
thanks for your check!
I can’t replicate the error you posted, could you share one *.EDX, one *.EDT and *.INX? thanks!
- Antonello
Hi Antonello,
This happens when i just insert the component. It is not related to any input file.
Testing the code i get:
Runtime error (SystemException): ‘unicodeescape’ codec can’t decode bytes in position 383: malformed \N character escape
Traceback (most recent call last):
SystemError: ‘unicodeescape’ codec can’t decode bytes in position 383: malformed \N character escape
See image both components, one connected and one not connected.
One more thing:
If you use Biomet then you have another directory at the level of other output directories (i.e. atmosphere, radiation, etc). Inside it you’ll find another set of directories (PMV, PET, UTCI) depending which comfort standard you asked for (could be all of them).
Hope it helps to get all results that were missing.
This looks fantastic Antonello !!
Thank you for developing it, and sharing the link to your publication!!!
Is is possible to attach some *.edx, .edt example files?
hi Abraham,
This looks similar to an issue of compatibility between python 2 and python 3.
Python 2.7.12
>>> print 'TEST\N\N’
Python 3.6.0
>>> print(‘TEST\N\N’)
SyntaxError: (unicode error) ‘unicodeescape’ codec can’t decode bytes in position 4-5: malformed \N character escape
>>> print(r’TEST\N\N’)
I should find a solution. Please, if you have occasion, let me know if it gives the same issue also with other computers.
Thanks for the hint about Biomet folder, it should be a good opportunity to compare results comes from envimet and ladybug.
Hi Antonello,
Sorry to say that i have the same problem on my other computer :frowning:
Uninstalled Python 3.5 and installed 2.7 but no change.
Hi guys
Rhino does not use independent installations of IronPython, but they can conflict with the version loaded from Rhino’s installation folder. As such, you should not install different IronPython versions to begin with. See more information.
If required, then rather install the exact version that you are using with Rhino, or disable the GAC option while installing.
Besides, \N is not a good character escape. It should be \n. \n is a new line escape. \N is undefined, even in Python 2.0, and as such, can create issues. I am not an expert regarding under which conditions an error will be raised for this problem, rather than being silently ignored.
Hi Antonello and Giulio,
Following Giulio’s recommendation i replaced all “\N” for “\n” and now it works!!
Looks great!!
I’ll keep checking.
Hi Giulio,
thank you for your precious contribute! Yes, I know that \N is not an escape character ;), but believe me I didn’t know where it was hidden inside the code…
Hi Abraham,
thanks for your work! send a pull request and mainly, can you show me where these “\N” are in the code? XD
  • Antonello
Hi Antonello,
There are only 2 “\N” at lines 35 and 117. If you change them to “\n” or “\N” then it works.
Waiting for the Biomet/UTCI, PMV, PET to be included in the studyFolder input :slight_smile:
It works with Thermal Comfort Indices component too:
Thank you Antonello for providing the example file, simulation files and guidance!!
ENVI-met simulation files need to be extracted to “c:” partition in order for the .gh file to work. (538 KB)
This is nice Djordje.
Just in case Antonello has the chance to include the Biomet comfort results i include here an example of this (since Biomet is commercial).
The directory structure is a bit different than the standard results.
Thank you for the Biomet example file Abraham!
Hi Abraham,
Thanks for your sharing, this can help me complete the component.
  • Antonello
