hi guys,
I’ve been following many discussions on ENVI-met in grasshopper and other alternatives with ladybug/honeybee (PET analysis and others). I must say that I’m now lost with all these possibilities.
My main objective is to perform an urban outdoor comfort analysis at the scale of max 1km radius in a city (maybe it is too much…).
As I’m digging deeper, and correct me if I’m wrong, ENVI-met approach seems to be the most complete ?
Now excuse this novice question, but concerning LB-ENVI-met, does it require ENVI-met software last version 4.3.2 (quite expensive for a student 400$CAN/year) Or it may work with previous version like ENVI-met 4 or 3.1 (is it free)? And where I can found it ?
All info I found about Grasshopper and ENVI-met:
- https://github.com/AntonelloDN/lb_envimet
- Ladybug_ENVI-Met Release
- http://www.grasshopper3d.com/forum/topics/gismo-ladybug-envi-met-connection?groupUrl=gismo&groupId=2985220%3AGroup%3A1680240&id=2985220%3ATopic%3A1720663&page=2#comments
And for those who already explore something similar as ENVI-met with Ladybug component, what doest it represent in terms of complexity ?
- http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Outdoor_Microclimate_Map&slide=0&scale=1&offset=-66.94754893551863,31.244801444676114
- PET example in Ladybug
- http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Trees_in_Outdoor_Thermal_Comfort&slide=1&scale=1&offset=0,0
All your advices and tips about running a complexe urban analysis are welcome !
I truly appreciate all your work, efforts, and supports !
Thank you guys,
Charles C.
