DISAM
1
Im getting the following errors im trying to run simple surface temp analysis with a customized composite panel
the materials are being added to the library there is no error there
it would be of great help if someone can look into the files attached below
- The simulation has not run correctly because of this severe error:
** Severe ** Weather Simulation requested, but no weather file attached.
** Severe ** GetNextEnvironment: Errors found in getting a new environment
- The simulation has failed because of this fatal error:
** Fatal ** Error condition occurred. Previous Severe Errors cause termination.
with volume.gh (608.0 KB)
See:
This happens because an illegal weather file path.
hi dear mostapha i have 3 error in my file in energy plus component
please help me for solve it
If you haven’t found the solution already start a new topic and follow the suggestion here and someone should be able to help you.
https://discourse.ladybug.tools/faq
The folder where you located your .epw has a space in its path, put it on the desktop and see if it works ?
