I have a similar problem, My Openfoam version is 4.1. I want to generate a heat source using fvOptions on one face of a box in my geometry. I made geometry in Salome. To select one surface of a box, I am using topoSetDict to make the selected patch a faceSet, and then using that faceSet I need to make a cellSet. When I run the case, it shows that the faceSet and cellSet are successfully created but then I get the following error:
--> FOAM FATAL ERROR:
Illegal content 8200 of set:hotcell of type cellSet
Value should be between 0 and 6396
From function void Foam::topoSet::check(Foam::label)
in file sets/topoSets/topoSet.C at line 189.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::topoSet::check(int) at ??:?
#3 Foam::cellSet::cellSet(Foam::polyMesh const&, Foam::word const&, Foam::IOobject::readOption, Foam::IOobject::writeOption) at ??:?
#4 Foam::fv::cellSetOption::setCellSet() at ??:?
#5 Foam::fv::cellSetOption::cellSetOption(Foam::word const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#6 Foam::fv::option::adddictionaryConstructorToTable<Foam::fv::SemiImplicitSource<double> >::New(Foam::word const&, Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#7 Foam::fv::option::New(Foam::word const&, Foam::dictionary const&, Foam::fvMesh const&) at ??:?
#8 Foam::fv::optionList::reset(Foam::dictionary const&) at ??:?
#9 Foam::fv::optionList::optionList(Foam::fvMesh const&, Foam::dictionary const&) at ??:?
#10 Foam::fv::options::options(Foam::fvMesh const&) at ??:?
#11 ? at ??:?
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13 ? at ??:?
Aborted (core dumped)
My topoSetDict is given below:
actions
name hot1;
type faceSet;
action new;
source patchToFace;
sourceInfo
name "hotFace";
// Select based on faceSet
name hotcell;
type cellSet;
action new;
source faceToCell;
sourceInfo
set hot1; // Name of faceSet
//option neighbour; // cell with neighbour in faceSet
//option owner; // ,, owner
option any; // cell with any face in faceSet
//option all; // cell with all faces in faceSet
And my fvOptions file is given below:
heatSource
type scalarSemiImplicitSource;
active true;
scalarSemiImplicitSourceCoeffs
selectionMode cellSet; // all, cellSet, cellZone, points
// cellZone hotcellZone;
cellSet hotcell;
volumeMode specific; // absolute;
injectionRateSuSp
h (2600 0);
And the log file of topoSetDict is given below:
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
mesh not changed.
Created faceSet hot1
Applying source patchToFace
Adding all faces of patch hotFace ...
Found matching patch hotFace with 253 faces.
faceSet hot1 now size 253
Created cellSet hotcell
Applying source faceToCell
Adding cells according to faceSet hot1 ...
cellSet hotcell now size 253
End
I don’t know what I am doing wrong. Maybe I am doing very obvious mistake.
I shall be very thankful for your help.
Thank you
