Agent-Based Building Simulation
You re definitely right about this…
I still did not reach any clear conclusion, I am working on a similar prototype of my patent and paper that I shared here before, but in a more complicated way…This time-step-based approach is really tricky, because in case of using indoor sensors there are many current limitations that E+ suffers … like daylight/glare metrics…
My working scale is not a huge one , I am working to find a method to link occupant-behavioral patterns on shading system from different perspectives of thermal and visual comfort,
I ll check your method as well… and will be happy to share anything with you …
Cheers
Amir
