Sorry for the late response. Glad that you were able to create the DataCollection objects and the issue that you experienced was a bug. I just pushed a fix to the Dragonfly repo:
… and I updated the hydra example file:
So, if you re-download the new hydra example and use the new “Create EPW” component, everything should work. Thank you for reporting the issue!
