Leonardo- Here is an example that might be helpful to get you started: http://www.grasshopper3d.com/group/ladybug/forum/topics/knowledge-s…
One the other hand you may want to separate your PV surfaces from building surfaces, otherwise you probably don’t want to use solar envelope. I saw that you are discussing this on another discussion so I leave the reasons to that discussion.
Mostapha
