Does this definition work with the 0.0.03 version of butterfly? Like Lamine above, I get exception errors asking if butterfly is installed, yet when I run other butterfly definitions, they work as expected.
Many thanks in advance.
Hi Andrew, You need to update manually this def with reinserting new components.
Some way was changed in new version. Or itās better, you can switch this approach(H UI) to Butterfly Sample files locate in Butterfly installation folder.
Regards,
Omid.
In this path, you can find them:
C:\Users%UserNAME%\AppData\Roaming\McNeel\Rhinoceros\5.0\scripts\Butterfly\
Hi Omid,
Ah, I did wonder if that was the case, I started tow swap out some components, but they have slightly different terminals etc, so the definition canāt easily be swapped about.
Iāll take a look at the sample foldersā¦
Thanks again.
PS, if anyone manages to update the definition in this thread to work with the new version of butterfly, Iād appreciate the link, Iām quite new to Grasshopper and find it quite daunting!
Hmm, no demo files in that location?
Hi Andrew,
I am sorry for the late reply.
BF has gone through a few changes since I posted this definition. We are getting closer to a public release were we will include a series of examples to showcase itās potential.
I will try and get the time to update this example and include it along the others, it shouldnāt take too long.
Kind regards,
Theodore.
Hello Olivier
I tried to download this file but itās not working
May you share it with me via email: ahmed_7afez@eng.cu.edu.eg
@Ahmed.H.Hafez Please check your email.And here is a wetransfer shared link Unique Download Link | WeTransfer
