Cooling Load componenets after thermal lag calculations?
@josh.greenfield ,
I apologize for such a late reply. Yes, you can absolutely do this. If you are interested in understanding the cooling load contribution on a peak summer design day, this example file has exactly what you are looking for:
http://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Visualize_Peak_Loads_for_HVAC_Sizing&slide=0&scale=1&offset=0,0
You will see that you get outputs of both instantaneous heat entering the space and the estimated cooling load, which accounts for thermal lag.
