Customized bldgProgram & zoneProgram lists
Hi Chris,
Thanks for the advice, it works decently well. It would be much nicer to be able to customize the program list, but for now I entered the info in panels, and then assign it using the setEPZoneLoads etc. components. If anyone else is thinking about doing this, you can clean up the code by just clustering that part of your program.
Cheers,
M’Beth
