Fairyfly could not find the log file
This exception message does not seem to be correct:
Do you not have a user name on this machine? Or did you just edit the message before you posted here?
What happens when you just write the .THMZ file with the component but then open it in the THERM interface to simulate it? If that workflow doesn’t function correctly, then we know that it is a problem with your THERM installation.
