Grasshopper DataOut / DataIn with Honeybee
@thomas.wortmann ,
It sounds like you are trying to pass Python objects back and forth between Grasshopper definitions, which can work when both definitions are open but, if you close one, the object could get deleted. The legacy plugins weren’t really set up to do anything beyond passing objects within one definition so I don’t think there’s really a way to get your specific example to work.
However, in the new LBT plugin that was released last week, you can serialize Python objects into JSON strings that can then be re-serialized to objects in other definitions. Since you are only passing strings between definitions, you should be able to set it up such that it doesn’t matter if you close one definition. So my recommendation for the time being would be to try and see if you can get things to work with the new plugin.
