HB+ sDA Calculation - 2% of points
Hi @Riley.Johnson
I am using “honeybeeplus hourly values” component to generate blind state which meet IES 2% requirement.
As below screenshots (there are two window groups in this model), we can get number of points which exceeds 1000lux direct sunlight per each hour to define if the blind need to be closed or not, then we can make a customized blind state data-set which can be connected to the sDA component.
