HB UTCI outdoor grid wind
Are you using the latest LBT UTCI Comfort Map component that you can get by running the LB Versioner component? That one has the capability of accepting a folder with CSVs of hourly air speeds for each sensor in the model sensor grids. See here for more information:
I would only consider using a model like SET if you know exactly what clothing and metabolic rate the people will have. If not, then UTCI is probably still a better model for your case here.
