Honeybee plus - annual daylight Vs daylight cofficent recipe
Hello @sarith and @Matteo
I’m writing an article simulated with HB Plus. And annual simulations are performed seasonally (3 MOUNTH). And of course the results seem a bit illogical. And to justify this difference, I need to explain in the method section.
This explanation that you have given in this discussion is very appropriate; But it needs resources.
What sources should I rely on in my article to explain this difference in results between HB lagacy and hb plus?
Thank you in advance for your help
This is the paper where we explained the difference between Daysim (HB-Legacy) and the improved method (HB-Plus): https://www.researchgate.net/publication/325248556_A_more_accurate_approach_for_calculating_illuminance_with_daylight_coefficients
Regards,
Sarith
thank you so much for your reply, quickly. :pray:
