HI, @hdimor.mr
I’ve faced the same problem. Now it is working smoothly. Thanks.
Hi, I tried to reinstall HB and Ladybug from food4rhino for v0.0.63 and 0.0.66 respectively per the instruction above. Honeybee still gives me these 2 errors:
- Failed to download the files needed to run EnergyPlus with OpenStudio 2.x.
SystemError(‘The remote server returned an error: (503) Server Unavailable.’,)
- Failed to download the files needed to PostProcess EnergyPlus results with OpenStudio 2.x.
SystemError(‘An exception occurred during a WebClient request.’,)
What files is it looking for?
If i save the files manually, which folder should i use?
Thanks.
Thanks!
@inkmug, You can Download LB & HB update fixed sample file from here:
P.S. So, you don’t need to download Honeybee master.zip (resource folder_EPRunFiles) and put them manually.
Thanks @OmidmRashid, I tried that but it still gives me this error for Honeybee.
i.
I think in my previous post, my HB is updated, just missing some file path to some openstudio files. Is there a way to know which file and which file path?
yes, this fixed the issue. Thanks!
