HVAC Geothermal Heat Pump with Floor Radiant ASHRAE 90.1
Hi @MingboPeng,
I had a test.
  1. I have set a simple box with all adiabatic surfaces, space type “Office::OpenOffice”.
  2. I have added a probe to check supply exit node.
  3. I have added a switcher to change supply type: Geothermal Heat Pump or District Heating cooling.
GSHP Results:
  1. Series of warning because inner air temperature is extreme.
  2. Probe results:
District Heating/Cooling results:
  2. Probe results:
Other tests:
  1. Plenum zone test:
  2. Packaged VAV with reheat
At this point, I am pretty sure there are some errors in how I have modeled plant loops and setpoint.
Could you take a look at this new file and give me a feedback about results above?
Ironbug_HVAC_test00_GSHP_probe_test.gh (818.2 KB)
Thanks,
Antonello
