Hi @MingboPeng ,
I encountered an issue when applying the idealLoad system to the DF Detailed HVAC object. It seems that this system doesn’t work with DF Detailed HVAC. However, when I apply other HVAC systems like DF IdealAirLoad, it functions as expected.
Interestingly, if I take the same detailed ironbug system and apply it to the hbmodel created with DF Create Geojson, the Honeybee simulation works, and it creates the detailed system successfully. In the screenshots attached earlier, you can see that the detailed IDF system is created correctly. However, it doesn’t seem to be applied to the room with DF Detailed HVAC.
I am in the process of creating a workflow that allows for the application of different HVAC systems to different rooms. It’s possible that the issue is more related to Dragonfly or Grasshopper rather than Ironbug.
I have another cuestion related the IdealAirLoad component.I create another post here: IdealAirLoad system with Outdoor Air Inlet Node Name
