Dear Chris
I’m using ladybug tools 1.5, is there any way to import material and construction from idf file or create material and construction via text panel?
@chris
Hi,@xiaoyuling
You can use text split\replace compotent to create material via text panel copied from Enerygplus idf file.
chris
July 24, 2023, 10:07pm
3
Also see here, @xiaoyuling :
Hello everyone,
I am in the process of learning the workflow of the new Honeybee and Ladybug Tools. I have an OSM and IDF file that purely contains customized construction sets and materials that I usually work with and I was wondering whether there is a way to import them into the new Honeybee without having to recreate each of them inside the grasshopper and copy pasting them every time I make a new model?
I am aware that there is an import OSM IDF component, but to my understanding it only …
I believe the workflow there likely gives you want you want.
Thank u for this suggestion,it is very useful
