@AbrahamYezioro Yes, I want to make a u-shaped awning, but it doesn’t seem to work well. Thank you!house01.gh (514.2 KB)
This is a “difficult” base surface to solve. The algorithm used for the component can’t deal with “every surface”. In this case you have a surface bended almost orthogonally.
For now this is the best you can get.
I suggest, maybe, to split the surface into 3 separated ones …
I will try it. Thanks!
Hi @AntonelloDiNunzio,
Maybe you have ideas to suggest here?
