Location for applying HVAC components (HB-Energy)
Thanks for trying to answer the question, @JimMarsh , and you’re right that is the correct way to assign HVAC systems but I think @DreamADreammmm2023 is asking specifically why the HB Thermal Load Balance is not working when a detailed HVAC template is assigned.
@DreamADreammmm2023 , this should give you the answer to your question:
In short, you need to use ideal air systems if you want to use the thermal load balance component.
