I update more info of the problem, If i set Custom output: Zone Ideal Loads Supply Air Standard Density Volume Flow Rate. The results show the m3/s of supply air I set.
So it might be correct, How can I see the energy impact of the HB Ventilation without heat recovery ?
Update 2: I tried also setting “all” in load type, and it says null (See No Mechanical Ventilation in Ideal Air Loads results).
Finally, as I see, the cooling and heating output change if I change the ventilation values, so Its work. As a result, I decide to do this to see the ventilation loads, creating two simulations: One with ventilation and other without ventilation, and the difference between cooling and heating result (with and without ventilation) is the ventilation loads.
