It will make the results wrong. I think I finally figured why this is happening. The behavior of transform function in RhinoCommon is different from what I was expecting it to do. I need to flip the surfaces after transform if needed. I’ll try to get it fix on my train ride back home.
Ok! I think I have it fixed.
Back to naming have you seen get or set Names component? You can get the names and add a new part to the name based on the transformation. Is that make the process easy enough?
HB_Transformations_msr.gh (534 KB)
