Farzane,
In life there is only one sure thing ā¦
Though, from your picture, iām pretty sure there is a normal direction issue. Upload your file (with geometry internalised) or check yourself with the dir command (if rhino model) or show the normals with native GH components.
here is my file, I will appreciate if you check it and help me through this issue.
thanks,
radiation analysis.gh (399 KB)
Your file is running fine at my end:
Are you getting any values from the selectSkyMtx?
I get zero for all the days!!!
I changed epw file for different locations but still get the same result.
I run sunlight hour analysis with the same setting and I get the result but it does not work with radiation analysis
Probably the problem is with the gendaymtx.exe file.
Check this discussions: 1, 2. If needed download the program here.
