Proper way to 'get' window construction?
@edpmay ,
Your screenshot shows the indented behavior and it seems likely that you are just misunderstanding how ConstructionSets work (you are not the first).
This post explains what is happening:
The fact that you apply an individual construction directly to the Aperture is overriding the construction assigned by the Room ConstructionSet.
