I am interested saving a bunch of views for rendering and then process them through a custom batch file.
Is it possible to capture viewport coordinates and view direction from Rhino viewport in Honeybee ? I know that it is possible to create renderings through Honeybee_Run daylight simulation. Is there a way to bypass the whole rendering process and only extract the view files instead ?
Typical configuration of a view file looks like this (vp and vd correspond to viewpoint and view-direction respectively):
In case you don’t want to deal with the code, you can connect multiple view names to imageBased recipe. Then only set writeRad to True. All the views will be written in the file in the rpict line and you can copy-paste them into your file.
Hi Sarith, It’s definitely not . Results output should be renamed after the simulation and outputs the files. I checked with the latest version and it works fine on my system so I assume it has been fixed at some point. Thanks for reporting! Mostapha
