Right, but the question here is about a “yearly average” analysis for an entire floor plan, which my professor says would take 10 hours with a good computing power, compared to 15 minutes for Sefaira. If you have a life, you won’t increase the values as you suggest because it would take such a long amount of time.
Is Sefaira a good alternative or is it so inaccurate that it’s not worth using?
Below is the Sefaira version of my radiation, not including interior walls, that only took 15 minutes
