Have folks had luck getting Rhino 7 to work with THERM 7.6?
I’ve tried going through the steps outlined in this thread, but continue to get the same error copied below. I’ve used the LB Versioner component and have attempted to update to an older version 0.0.65 and the newest version 1.3.23.
Is there a different component I should attempt to use? If, so which one and what version is best?
“1. Your simulation did not run correctly because of the following error:
The geometry contains voids or overlapping regions. The edges surrounding these regions will be highlighted in red. You must fix this problem before simulating. Regenerating Boundary Conditions may correct this in some cases.The geometry contains overlapping regions. The edges surrounding these regions will be highlighted in red. You must fix this problem before simulating. ID(s): 12There are materials that lie outside of the Boundary ConditionsModel geometry and Boundary Conditions need to be properly defined before a calculation can be performed.”
