Runtime error (ArgumentException): Instance property 'Item008' is not defined for type
Hello @mostapha,
Thank you for your reply. I will try my best to solve this myself or try other alternatives. If I have not figured out solutions by April 25 I will certainly let you know. However, I do need to find a solution as soon as possible so that I can move forward with the parametric studies that require calling HB/LB plugins iteratively. Anyhow, thank you so much for your help!
Best,
SZ
