Set ground floor
Hi what I did is insert a surface at the bottom of the building at the horizontal x-y plan. And in the grasshopper interface, I use the create surface component to create the surface and assign properties to it but I only use it for Radiance analysis. Maybe there is other solutions to it.
There are some similar post about ground surface like this.
Hope that helps.
