"too many values to unpack" error with Part 6 of the Honeybee video tutorials
Chris’s suggestion is the best: Not good to mix versions of LB+HB with the different components.
So the best is to start over from the example and apply your changes
or
Update the different components in your example. From your image i see that the E+Run component is from Sept 15, and i recall that the HB is from January 11.
You can also use the HB/LB updater components to do this dirty job for you (in case you have many components to update).
