I’m still unable to use any of the Ladybug/Honeybee components and getting the “failed to import…” errors.
I have added the paths manually to the Python Search paths too.
Output when I run
import sys
print(‘\n’.join(sys.path))
C:\Program Files\Rhino 6\Plug-ins\IronPython\Lib
C:\Users\TSA94506\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib
C:\Users\TSA94506\AppData\Roaming\McNeel\Rhinoceros\6.0\scripts
C:\Users\TSA94506\ladybug_tools\python\Lib\site-packages
renwei
June 28, 2021, 10:18am
23
I also meet this problem, how can I solve this, really thanks if there is anyone can help me!
Renwei
I am getting the same error, I am using it on mac (OSX). I couldn’t find the python file (in users folder) which needs to run in step 4.
Thanks in advance.
chris
August 16, 2021, 11:41pm
25
There is no .bat file to run when you are on OSX. See the Mac installation instructions:
If you’re still having difficulty, try deleting the folder at:
/Users/[USERNAME]/ladybug_tools
Then, re-run the installer.gh
Just to add my 2 cents here for Mac installations.
Once you’ve followed all the instructions, make sure to right click Rhino and Quit before relaunching.
Simply closing a Rhino window on Mac won’t reload all the changes made by the instalations.
Maybe trivial, but I did go in circles for a while.
