There’s not enough information here to know for sure. Do you have any non-ASCII characters in your username? It’s possible that you found a case with non-ASCII characters that we missed.
The file works perfectly on rhino6, but it has this problem in rhino7. rhino7 version number is 7.13
@chris This issue remains unresolved
Can you upgrade to the latest version of Rhino 7 and see if the issue persists? Can you also check to make sure that you’re using the same units system and tolerance in Rhino 6 and Rhino 7?
