0. SnappyHexMeshDict.snapControls.extractFeaturesRefineLevel is changed from "true" to "3". 1. updating snappyHexMeshDict for Explicit Edge Refinement. 2. saving the new snappyHexMeshDict
        {0;0}
  1. SnappyHexMeshDict.snapControls.extractFeaturesRefineLevel is changed from “true” to “3”.
  2. updating snappyHexMeshDict for Explicit Edge Refinement.
  3. saving the new snappyHexMeshDict.
  4. /---------------------------------------------------------------------------
    | \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
    | \ / O peration | Version: 5.x |
    | \ / A nd | Web: www.OpenFOAM.org |
    | \/ M anipulation | |
    Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt
    | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
    Build : 5.x-963176928289
    Exec : surfaceFeatureExtract
    Date : Jul 18 2022
    Time : 13:03:17
    Host : “DESKTOP-R5NE1TH”
    PID : 25256
    I/O : uncollated
    Case : c:/Users/Administrator/butterfly/outdoor_airflow
    nProcs : 1
    SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
    allowSystemOperations : Allowing user-supplied system call operations
Create time
Reading surfaceFeatureExtractDict
Surface : “outdoor_airflow.stl”
Feature line extraction is only valid on closed manifold surfaces.
Statistics:
Triangles : 24
Vertices : 16
Bounding Box : (6.2141218 9.0591459 0) (25.232334 33.548717 7.0631461)
Constructing feature set from included angle 150
Selecting edges purely based on geometric tests: on
Initial feature set:
feature points : 16
feature edges : 24
of which
region edges : 0
external edges : 24
internal edges : 0
Final feature set:
of which
convex : 16
concave : 0
mixed : 0
non-feature : 0
edges : 24
of which
external edges : 24
internal edges : 0
flat edges : 0
open edges : 0
multiply connected : 0
Writing extendedFeatureEdgeMesh to “c:/Users/Administrator/butterfly/outdoor_airflow/constant/extendedFeatureEdgeMesh/outdoor_airflow.extendedFeatureEdgeMesh”
Writing featureEdgeMesh to “c:/Users/Administrator/butterfly/outdoor_airflow/constant/triSurface/outdoor_airflow.eMesh”
ExecutionTime = 0.004 s ClockTime = 0 s
End
Exec : decomposePar
Date : Jul 18 2022
Time : 13:03:18
PID : 27212
I/O : uncollated
nProcs : 1
Create time
Decomposing mesh region0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod scotch
Finished decomposition in 0.128 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Processor 0
Number of cells = 6071
Number of faces shared with processor 1 = 469
Number of faces shared with processor 2 = 145
Number of faces shared with processor 3 = 118
Number of faces shared with processor 4 = 147
Number of faces shared with processor 6 = 352
Number of faces shared with processor 7 = 131
Number of processor patches = 6
Number of processor faces = 1362
Number of boundary faces = 860
Processor 1
Number of cells = 5958
Number of faces shared with processor 0 = 469
Number of faces shared with processor 2 = 268
Number of faces shared with processor 3 = 140
Number of processor patches = 3
Number of processor faces = 877
Number of boundary faces = 1273
Processor 2
Number of cells = 6009
Number of faces shared with processor 0 = 145
Number of faces shared with processor 1 = 268
Number of faces shared with processor 3 = 547
Number of faces shared with processor 4 = 279
Number of processor patches = 4
Number of processor faces = 1239
Number of boundary faces = 1019
Processor 3
Number of cells = 6054
Number of faces shared with processor 0 = 118
Number of faces shared with processor 1 = 140
Number of faces shared with processor 2 = 547
Number of faces shared with processor 4 = 296
Number of processor faces = 1101
Number of boundary faces = 1101
Processor 4
Number of cells = 6068
Number of faces shared with processor 0 = 147
Number of faces shared with processor 2 = 279
Number of faces shared with processor 3 = 296
Number of faces shared with processor 5 = 403
Number of faces shared with processor 6 = 60
Number of faces shared with processor 7 = 269
Number of processor faces = 1454
Number of boundary faces = 822
Processor 5
Number of cells = 5953
Number of faces shared with processor 4 = 403
Number of faces shared with processor 7 = 372
Number of processor patches = 2
Number of processor faces = 775
Number of boundary faces = 1253
Processor 6
Number of cells = 6022
Number of faces shared with processor 0 = 352
Number of faces shared with processor 4 = 60
Number of faces shared with processor 7 = 628
Number of processor faces = 1040
Number of boundary faces = 1256
Processor 7
Number of faces shared with processor 0 = 131
Number of faces shared with processor 4 = 269
Number of faces shared with processor 5 = 372
Number of faces shared with processor 6 = 628
Number of processor faces = 1400
Number of boundary faces = 830
Number of processor faces = 4624
Max number of cells = 6071 (0.98766972% above average 6011.625)
Max number of processor patches = 6 (50% above average 4)
Max number of faces between processors = 1454 (25.778547% above average 1156)
Time = 0
→ FOAM Warning :
From function bool Foam::IOobject::readHeader(Foam::Istream&)
in file db/IOobject/IOobjectReadHeader.T.C at line 88
Reading “c:/Users/Administrator/butterfly/outdoor_airflow/0/ABLConditions” at line 11
First token could not be read or is not the keyword ‘FoamFile’
Check header is of the form:
/--------------------------------- C++ -----------------------------------
FoamFile
version 2.0;
format ascii;
class IOobject;
location “0”;
object ABLConditions;
→ FOAM Warning :
Reading “c:/Users/Administrator/butterfly/outdoor_airflow/0/initialConditions” at line 11
FoamFile
version 2.0;
format ascii;
class IOobject;
location “0”;
object initialConditions;
Processor 0: field transfer
Processor 1: field transfer
Processor 2: field transfer
Processor 3: field transfer
Processor 4: field transfer
Processor 5: field transfer
Processor 6: field transfer
Processor 7: field transfer
End
Exec : snappyHexMesh
Date : Jul 18 2022
Time : 11:15:23
PID : 8720
I/O : uncollated
nProcs : 1
Create time
Create mesh for time = 0
Read mesh in = 0.24 s
Overall mesh bounding box : (-29.101609 -12.130292 0) (60.548064 139.49591 35.315731)
Relative tolerance : 1e-006
Absolute matching distance : 0.0001796518
Reading refinement surfaces.
Read refinement surfaces in = 0.001 s
Reading refinement shells.
Refinement level 3 for all cells inside around_buildings_area.stl
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
Read edgeMesh outdoor_airflow.eMesh
edges : 24
boundingBox : (6.2141218 9.0591459 0) (25.232334 33.548717 7.0631461)
Refinement level according to distance to “outdoor_airflow.eMesh” (16 points, 24 edges).
level 3 for all cells within 0 metre.
Read features in = 0.001 s
Determining initial surface intersections
Edge intersection testing:
Number of edges : 148486
Number of edges to retest : 148486
Number of intersected edges : 968
Calculated surface intersections in = 0.121 s
Initial mesh : cells:48093 faces:148486 points:52416
Cells per refinement level:
0 48093
Adding patches for surface regions
Patch Type Region
outdoor_airflow:
6 wall buildings
Added patches in = 0.004 s
Selecting decompositionMethod none
Layer thickness specified as final layer and expansion ratio.
Refinement phase
Found point (15.723228 63.682808 17.657865) in cell 41554 on processor 0
Feature refinement iteration 0
Marked for refinement due to explicit features : 196 cells.
Determined cells to refine in = 0.273 s
Selected for feature refinement : 196 cells (out of 48093)
Number of edges : 153754
Number of edges to retest : 8816
Number of intersected edges : 1920
Refined mesh in = 0.16 s
After refinement feature refinement iteration 0 : cells:49465 faces:153754 points:55120
0 47897
1 1568
Feature refinement iteration 1
Marked for refinement due to explicit features : 401 cells.
Determined cells to refine in = 0.259 s
Selected for feature refinement : 720 cells (out of 49465)
Number of edges : 172171
Number of edges to retest : 27571
Number of intersected edges : 4039
Refined mesh in = 0.202 s
After refinement feature refinement iteration 1 : cells:54505 faces:172171 points:63829
0 47578
1 3719
2 3208
Feature refinement iteration 2
Marked for refinement due to explicit features : 821 cells.
Determined cells to refine in = 0.249 s
Selected for feature refinement : 1700 cells (out of 54505)
Number of edges : 214930
Number of edges to retest : 65022
Number of intersected edges : 9179
Refined mesh in = 0.261 s
After refinement feature refinement iteration 2 : cells:66405 faces:214930 points:83566
0 47369
1 4714
2 7810
3 6512
Feature refinement iteration 3
Marked for refinement due to explicit features : 14 cells.
Determined cells to refine in = 0.48 s
Selected for feature refinement : 22 cells (out of 66405)
Number of edges : 215491
Number of edges to retest : 972
Number of intersected edges : 9283
Refined mesh in = 0.238 s
After refinement feature refinement iteration 3 : cells:66559 faces:215491 points:83829
0 47367
1 4724
2 7844
3 6624
Feature refinement iteration 4
Marked for refinement due to explicit features : 0 cells.
Determined cells to refine in = 0.531 s
Selected for feature refinement : 0 cells (out of 66559)
Stopping refining since too few cells selected.
Surface refinement iteration 0
Marked for refinement due to surface intersection : 10726 cells.
Determined cells to refine in = 0.004 s
Selected for refinement : 11693 cells (out of 66559)
Number of edges : 489919
Number of edges to retest : 344218
Number of intersected edges : 33636
Refined mesh in = 0.573 s
After refinement surface refinement iteration 0 : cells:148410 faces:489919 points:195843
0 46317
1 11327
2 17884
3 36802
4 36080
Surface refinement iteration 1
Marked for refinement due to surface intersection : 25384 cells.
Determined cells to refine in = 0.014 s
Selected for refinement : 26818 cells (out of 148410)
Number of edges : 1096648
Number of edges to retest : 871102
Number of intersected edges : 75558
Refined mesh in = 1.611 s
After refinement surface refinement iteration 1 : cells:336136 faces:1096648 points:426650
0 46203
1 7722
2 46891
3 78776
4 156544
Surface refinement iteration 2
Marked for refinement due to surface intersection : 41092 cells.
Determined cells to refine in = 0.036 s
Selected for refinement : 43514 cells (out of 336136)
Number of edges : 2070808
Number of edges to retest : 1371433
Number of intersected edges : 140134
Refined mesh in = 2.406 s
After refinement surface refinement iteration 2 : cells:640734 faces:2070808 points:790779
0 46053
1 7878
2 37999
3 191652
4 357152
Surface refinement iteration 3
Marked for refinement due to surface intersection : 63552 cells.
Determined cells to refine in = 0.048 s
Selected for refinement : 66320 cells (out of 640734)
Number of edges : 3558640
Number of edges to retest : 1992363
Number of intersected edges : 241254
Refined mesh in = 4.385 s
After refinement surface refinement iteration 3 : cells:1104974 faces:3558640 points:1348908
0 46053
1 7878
2 35231
3 150244
4 865568
Surface refinement iteration 4
Marked for refinement due to surface intersection : 0 cells.
Determined cells to refine in = 0.12 s
Selected for refinement : 0 cells (out of 1104974)
Removing mesh beyond surface intersections
Exec : reconstructParMesh -constant
Date : Jul 18 2022
Time : 13:03:19
PID : 14484
I/O : uncollated
nProcs : 1
Create time
This is an experimental tool which tries to merge individual processor
meshes back into one master mesh. Use it if the original master mesh has
been deleted or if the processor meshes have been modified (topology change).
This tool will write the resulting mesh to a new time step and construct
xxxxProcAddressing files in the processor meshes so reconstructPar can be
used to regenerate the fields on the master mesh.
Not well tested & use at your own risk!
Merge tolerance : 1e-007
Write tolerance : 1e-008
Doing geometric matching on correct procBoundaries only.
This assumes a correct decomposition.
Found 8 processor directories
Reading database “outdoor_airflow/processor0”
Reading database “outdoor_airflow/processor1”
Reading database “outdoor_airflow/processor2”
Reading database “outdoor_airflow/processor3”
Reading database “outdoor_airflow/processor4”
Reading database “outdoor_airflow/processor5”
Reading database “outdoor_airflow/processor6”
Reading database “outdoor_airflow/processor7”
Time = constant
Reading points from “outdoor_airflow/processor0” for time = constant
Reading points from “outdoor_airflow/processor1” for time = constant
Reading points from “outdoor_airflow/processor2” for time = constant
Reading points from “outdoor_airflow/processor3” for time = constant
Reading points from “outdoor_airflow/processor4” for time = constant
Reading points from “outdoor_airflow/processor5” for time = constant
Reading points from “outdoor_airflow/processor6” for time = constant
Reading points from “outdoor_airflow/processor7” for time = constant
Relative tolerance : 1e-007
Absolute matching distance : 1.796518e-005
Merging mesh 0 with 1
Merging mesh 2 with 3
Merging mesh 4 with 5
Merging mesh 6 with 7
Merging mesh 0 with 2
Merging mesh 4 with 6
Merging mesh 0 with 4
Reading mesh to add from “outdoor_airflow/processor0” for time = constant
Reading mesh to add from “outdoor_airflow/processor1” for time = constant
Reading mesh to add from “outdoor_airflow/processor2” for time = constant
Reading mesh to add from “outdoor_airflow/processor3” for time = constant
Reading mesh to add from “outdoor_airflow/processor4” for time = constant
Reading mesh to add from “outdoor_airflow/processor5” for time = constant
Reading mesh to add from “outdoor_airflow/processor6” for time = constant
Reading mesh to add from “outdoor_airflow/processor7” for time = constant
mergeSharedPoints : detected 0 points that are to be merged.
Writing merged mesh to “c:/Users/Administrator/butterfly/outdoor_airflow/constant”
Reconstructing the addressing from the processor meshes to the newly reconstructed mesh
Reading processor 0 mesh from “outdoor_airflow/processor0”
Writing pointProcAddressing to “outdoor_airflow/processor0/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor0/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor0/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor0/constant/polyMesh”
Reading processor 1 mesh from “outdoor_airflow/processor1”
Writing pointProcAddressing to “outdoor_airflow/processor1/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor1/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor1/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor1/constant/polyMesh”
Reading processor 2 mesh from “outdoor_airflow/processor2”
Writing pointProcAddressing to “outdoor_airflow/processor2/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor2/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor2/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor2/constant/polyMesh”
Reading processor 3 mesh from “outdoor_airflow/processor3”
Writing pointProcAddressing to “outdoor_airflow/processor3/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor3/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor3/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor3/constant/polyMesh”
Reading processor 4 mesh from “outdoor_airflow/processor4”
Writing pointProcAddressing to “outdoor_airflow/processor4/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor4/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor4/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor4/constant/polyMesh”
Reading processor 5 mesh from “outdoor_airflow/processor5”
Writing pointProcAddressing to “outdoor_airflow/processor5/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor5/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor5/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor5/constant/polyMesh”
Reading processor 6 mesh from “outdoor_airflow/processor6”
Writing pointProcAddressing to “outdoor_airflow/processor6/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor6/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor6/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor6/constant/polyMesh”
Reading processor 7 mesh from “outdoor_airflow/processor7”
Writing pointProcAddressing to “outdoor_airflow/processor7/constant/polyMesh”
Writing faceProcAddressing to “outdoor_airflow/processor7/constant/polyMesh”
Writing cellProcAddressing to “outdoor_airflow/processor7/constant/polyMesh”
Writing boundaryProcAddressing to “outdoor_airflow/processor7/constant/polyMesh”
End.
5. Failed to read C:\Users\Administrator\butterfly\outdoor_airflow\log\reconstructParMesh.err:
[Errno 2] 未能找到文件“C:\Users\Administrator\butterfly\outdoor_airflow\log\reconstructParMesh.err”。: C:\Users\Administrator\butterfly\outdoor_airflow\log\reconstructParMesh.err
6. Failed to read C:\Users\Administrator\butterfly\outdoor_airflow\log\rm.err:
[Errno 2] 未能找到文件“C:\Users\Administrator\butterfly\outdoor_airflow\log\rm.err”。: C:\Users\Administrator\butterfly\outdoor_airflow\log\rm.err
7. Generating stack trace…
Backtrace:
ZN10StackTraceC1Ev [0x705c1465+0x25]
module: C:\Program Files\blueCFD-Core-2017\ThirdParty-5.x\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
ZN4Foam5error10printStackERNS_7OstreamE [0x2731c88+0x218]
module: C:\Program Files\blueCFD-Core-2017\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
ZN4Foam7sigQuit14sigQuitHandlerEi [0x2733c23+0x33]
_pxcptinfoptrs [0x7ffbb706abcd+0xcd]
module: C:\Windows\System32\msvcrt.dll
CtrlRoutine [0x7ffbb4cfb943+0xc3]
module: C:\Windows\System32\KERNELBASE.dll
BaseThreadInitThunk [0x7ffbb6e77034+0x14]
module: C:\Windows\System32\KERNEL32.DLL
RtlUserThreadStart [0x7ffbb73e2651+0x21]
module: C:\Windows\SYSTEM32\ntdll.dll
^C
8. Runtime error (PythonException):
→ snappyHexMesh Failed!
Backtrace:
^C
Traceback:
line 135, in script
