Mostly this happens when the zone information does not match with the resultfile. This can be the case when you import the resultfile with the HB enrgyplus look-up folder component.
Thanks for checking the problem
However, after the connection was completed, new problems appeared, which made me a little disappointed. Could you please help me again?
You possibly have two different analysis periods in your model (warning 1), and maybe you’ve assigned a data branch of values only (warning 2), not a data collection. Somewhere - without seeing your file there isn’t much to say.
As none of your previous posts that I’ve seen has a .gh file attached to it, I assume you haven’t read the forum guidelines. It would help you getting more meaningful replies, if you post your questions accordingly:
