Hi Everyone,
I am still getting this message after installing energyplus and put it in the correct location.
This is the message the HB is showing:
- Honeybee cannot find a compatible EnergyPlus folder on your system.
Make sure you have EnergyPlus installed on your system.
You won’t be able to run energy simulations without EnergyPlus.
Honeybee supports following versions:
V8-4-0, V8-3-0, V8-2-10, V8-2-9, V8-2-8, V8-2-7, V8-2-6, V8-2-5, V8-2-4, V8-2-3, V8-2-2, V8-2-1, V8-2-0, V8-1-5, V8-1-4, V8-1-3, V8-1-2, V8-1-1, V8-1-0
Also, I have installed Openstudio at the correct location but still getting the following message:
- Cannot find OpenStudio libraries at
You need to download and install OpenStudio to be able to use this component.
FYI: I am using rhino7, and LB version 1-6-0
