Hello group,
Does anyone know how to deal with this 1. Solution exception:‘bool’ object has no attribute ‘upper’ - error? Or what can it be caused by?
As far as i remember close Gh/Rhino and restart from fresh. Or before that try to (right click) recompute the solution.
Does not work … I’ll try a restart …just in case
restart won’t do it either …
Is the file updated?
Uploading it can be more useful.
well i thought it was now i tried it on a simple geometry and it says that I should update HB - will try that now
same problem even after update …
Here is the file, if you manage to fix it i would appreciate a print screen on how to solve it …
squared building - 10-04-2016.gh (1.36 MB)
Hi Stefania,
the error is because you have connected a boolean parameter to altConstruction_.
Besides, I suggest you:
update your LB HB. The current version is the March version.
draw shadows surfaces in different way, much more schematic, in this way you could increase the speed of the calculation.
If you want take a look here:
http://nrel.github.io/EnergyPlus/Tips_and_Tricks_Using_EnergyPlus/T…
Best
Antonello
HELLO
I got HB daylight analysis, but I have the same problem, what should I do?
Possibly also you connected something wrong.
To be able to help you at least a screenshot or better a gh file( with geo internalized) would be needed.
