what can cause this problem? Is it because of a “corrupt” file? I got it from here, which looks legit: \climatewebsite\WMO_Region_6_Europe\DEU_Germany
Is there any way to check or load the file anyways?
Thanks and greets,
Martin
Update: pointing with LB Download Weather directly to the file and with Import STAT it gives the correct location.
