Any idea what this means? ive tried deleting the sample model grid folder from simulations and then running the script again but no luck. also had this issue with the daylight into energy sample file
Thanks
Hi @armitamatt,
Can you run LB Versioner, update the components on the canvas, and then check if the issue is still there?
Hi mikkel
yes that has worked, thanks
