Every single one of my Honeybee components in the definition are throwing an error 1. Solution exception:‘module’ object has no attribute ‘filterwarnings’. This definition worked previously and works for other colleagues. Any idea what may have happened?
Something seems to be awry with your Rhino IronPython plugin since filterwarnings comes from a native Python module, which you should be able to import like so:
Perhaps your version of Rhino is old? Or maybe you’re getting some interference from a version of IronPython that ships with Autodesk products. Are you on Windows?
Someone from the McNeel team like @wim might know more.
