I have no problem with the use of “split2floors” previously. However, I opened my old file recently and found that there is an error “1. Solution exception:name ‘debug’ is not defined” for the “split2floors” component.
Though most of the time it can be solved by recomputing the component, as my algorithm is an automated process for multiple cases, this error would be quite troublesome for me as I need to recompute again for each case.
This error is due to some stray code (for debugging) I left while I was modifying this component a year ago. I can send a PR with the fix tomorrow, which will solve this.
I have got the same problem as @Ivanita. The Honeybee_SplitBuildingMass2Floors gives an error (1. Solution exception:name ‘debug’ is not defined) where it didn’t do that before.
I have already updatet the honeybee components, as @SaeranVasanthakumar proposed, but the problem still occurs.
However, if I turn the boolean input for running the component to False and then back to True again it does work. But I do need it to work on opening since I’m using the script for an optimisation.
