HELLO!
Hi Pilippo, Can you open a GHPython node and type the lines below inside and let me know the results. I suspect that the path is not set correctly.
import sys
print sys.path
Mostapha
Hi Mostapha,
the test result:
[‘c:\Program Files\Rhinoceros 5 (64-bit)\Plug-ins\IronPython\Lib’, ‘C:\Users\FW A\AppData\Roaming\McNeel\Rhinoceros\5.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib’, ‘C:\Users\FW A\AppData\Roaming\McNeel\Rhinoceros\5.0\scripts’]
Filippo
Thanks. The path is there! Can you check this folder and let me know if you can see rhinoscriptsyntax.py?
(C:\Users\FWA\AppData\Roaming\McNeel\Rhinoceros\5.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib)
This is how it looks like on my machine:
…No… I miss both the rhinoscriptssyntax.py and scriptcontext.pyc…
Hi Mostapha,
any idea why I’m missing both files?
I tried to reinstall phino, GH and LB+HB but nothing changes…
Thank you
filippo
Hi Filippo,
This is an issue with Rhino installation. Your installation is missing rhinoscriptsyntax file. I would open a new discussion under errors and bugs and ask what is the solution to get installation fixed for rhinoscriptsyntax.py.
Ladybug + Honeybee doesn’t have anything to do with rhinoscriptsyntax installation itself. We just reference it in a number of the components.
Mosatpha
